I know how to add the 16:9 mask to multiple segments (by using the Segment mode and selecting several segments at once, then double-clicking the letterbox mask). But if you have a very long segment (a half-hour film for example), containing a lot of edits, is there a way to Segment-select the entire thing so I can add a 16:9 mask all at once? I'm thinking there's probably a better way--on a different track perhaps? I'm stumped.
EDIT: I'm no longer stumped, if anyone's interested in the procedure. The thing is you have to:
1) drag the pointer to select (i.e., "lasso") adjoining segments (switches you into Segment mode).
2) select your 16:9 mask in the effects first, THEN hold the Alt button, then double-click the 16:9 mask effect to apply the mask to all the lassoed segments.
3) with the Effects Pallette open, double click on a segment to re-position the framing as required (using Re-size).
That's how I letterbox an entire show in Avid Xpress I guess.
