Edweirdo said:the frosted (or ground) side faces your SLR lens, the clear side faces the DVX. If there is a condenser with the screen, the condenser (or curved) side faces the the SLR lens.
The slickest side faces the DVX. If you and the DVX are looking at the screen, the tab should be on the bottom right.zakaree said:generally yes.. but i cant tell the difference with this screen. both sides look the same to me.. one is a little glossier so im guessing that would be the condensor side
I got the 72mm Asian macro thinking that it would have a larger sweet spot and I would be zooming past the edge smearing, but clearly that is not the case. Here is some more footage with the Asian macro. I also just did a bokeh test with a different macro.ovjamaica said:The footage looks pretty good. Seems to be evenly lit across the screen. The two problems I am seeing (and they stem from the same component) is the edge smearing and chromatic aberration. Both are from the asian macro you are using. I know because I've used them before.Replace that with an achromat and you'll have a really nice image. Light loss seemed minimal (to be expected from the Ee-A) and the image seemed sharp enough. Nice work and good luck! :thumbup:
ep19 said:Here is a link to a mirror that reverses from left to right
http://www.exploratorium.edu/snacks/cylindrical_mirror.html
How you would use this with the 35mm adapter? I have no idea.
Papa: I could'nt open the LCD arm with a screwdriver to toggle that self shoot mode. It's too scary to rip open a DVX.
Check this link outzakaree said:let me screw around and figure out my final scotch tape design before i post some images.. (does anyone know if they make a supersized scotch tape roll.. something like the thickness of duct tape?)
StormFactory said:Check this link outSo the Scotch Tape you're using is frosted enought to catch the image? The stuff I have seems to be too clear.![]()
