24p or 23.98 for film transfer AUDIO SYNCH
Antoine_Fabi
Hi,
For a transfer to film, is it better to edit in a true 24p timeline or a 23.98 ?
I'm looking for perfect audio synch.
thanks
Hi David,
that would be, and by far, the easiest way.
...but what will happen if i give the Film transfer house an image sequence and an audio file that was syched to video at 23.98 fps ?
It will play a little faster than 23.98 , so...will the audio follow accordingly ?
will they accelerate the audio accordingly ?
This is extremely important because it is a sport commercial, fram accurate image/sound.
thanks
The most accurate way of going about it is to frameserve your project as individual frames -- there's 23.98 there; it's 24 pictures per second.
You would then submit your audio starting on the exact same frame. It will match up.
I wish i understand...
23.98 fps X 30 sec = 719.4 frames
24 fps fps X 30 sec = 720 frames
should not make a huge difference anyway...
thanks David !
if there are any sync issues, they will slow down your sound slightly to match. Edit in 23.98 since you shot digital and the footage is 23.98 anyways.
