salils
novelt said:what's recorded basically is data and the playback camera will read it. however if the camcorder doesn't display timecode doesn't mean it wasn't recorded or that it won't pass on that info to the NLE. i've captured from other camcorders and in my NLE (premiere) the timecode reads as it did when recorded. so what i guess you're really looking for is a camcorder that shows timecode. as stated above it's going to be 29.97fps regardless of mode...that's how the info is recorded.
Hmmm...I haven't tried it with Premiere, only Final Cut Pro. I don't get anytimecode coming in via firewire. I have it on advanced pulldown removal pre-set. I also tried switching it to just plain DV NTSC 48kHz (aka 60i) and that did not make any difference.
It looks like I'm not the only one with this problem:
http://www.pana3ccduser.com/showthread.php?t=5895
