(edit) Barkis gave the answer to this issue in post #10 on this thread. Message to self: RTFM!
I just updated to FCP 5.1.2, using software update on a G5 Quad. Everything worked fine, and the new import window is great.
One issue, however, is that the imported clips are still using 30 frame timecode. Each frame of timecode is tied to a frame of video, but each second goes up to frame 29, when frame 23 should be the last before going to frame 0 of the next second. I am also getting some discrepancies with stated duration versus actual duration. This is with the duration shown in the clip browser, as well as in the viewer.
The upshot of all this is that currently, timecode is not useful for playing with the clips - for example, if I figure I want to go ten seconds ahead, so I just type in ten second later timecode, well, it will be more than ten seconds later. Not good. Durations are not exact either.
When I drop a clip onto a 23.98 timeline, they play normally on the timelline without rendering and everything is fine.
The clip viewer in the P2 import window shows 30 frame time code, of course, because the original is 24 frames living within 30 frames with the advanced pulldown. That's all fine. When you step through, there will be 4 frames normally, then the fifth frame is the same as the fourth (the viewer doesn't show fields).
Is anyone else experiencing this? This is a nasty gotcha if you're not expecting it.
But otherwise, the new P2 import window rocks.
Verko
Verko
