Upload Here
Must be a problem...
--- 67.49.54.234 ping statistics ---
10 packets transmitted, 0 packets received, 100% packet loss
Jarred,
Just a thought... would it make sense to upload the H.264 files first, so that we could watch them? And then have a seperate deadline for the mpeg-2 files, after everyone has uploaded their 'less than 50MB' files?
There would be a lot more bandwidth and time available for all of the entries uploading before the deadline.
Just a thought?
Mine's going fast now that I connected. But it took like 3 hours to get a connection. thank god for software automation...
ill up the max users, the upload speed will go down but that way you can just get on and upload overnight.
nope, no problem, FTP is working fine.
Mine just restarted at 0%. It might have gotten deleted on the other end or the connection reset or something...It's okay, I'm just re-watching Ghostbuters :)
I just kicked someone off that was sitting there doing nothing for the last 30 minutes.. that musta been you :)
tommyinla said:
Hey Jarred, you should be able to adjust the idle times of the server.
unfortunately server side timeouts are no longer effective as most clients have simulated activity packets to avoid being idle, even when they are.
Ahh, the NOOP command at work...
and dont worry guys.. im not gonna kill the server while you guys still are uploading.. ill keep it up till everyones done.
im a bit confused.. i thogut the entries had to be 50mb, so why are some of the already uploaded vids on the ftp in the hundreds?
The online entry is restricted to 50MB. The DVD files (m2v) are going to be bigger, and they're being uploaded together.
guys dont worry about not making it.. ill make sure you all get them uploaded if your having problems. There are a crapload of people on the FTP right now, so i know its slow for yall.
