It's for recording live action stuff, like sports or news. Looks fantastic when shot at 50fps and played back at 50ps, a total "looking through a window" experience.Josh Wallace said:I do not really see the point of 720/50P as a capture format. It is always chewing up the maximum amount of space on your card. I never use it.
No, you're describing 720/25pN. 720/25p works exactly the same way as 720/50p does; it's there because you can only select variable frame rates in FILM CAM mode, so if you wanted to shoot the 25fps look in VIDEO CAM mode you'd need to use this mode.720/25P is essentially the same I think, but it is only recording 25 frames every second and if you shoot at a higher frame rate it adds more frames.
