DavidBeier
Finally got Barry's book and have been going through it page by page and experimenting. One thing that I'm still not clear on is the correlation between shutter speeds and frame rates in FILMCAM mode. If I turn the shudder off (just push the shudder button) then I see no difference in exposer when changing frame rates. When it's on, regaurdless of what shudder speed I set in the SyncoScan setting, the frame rate affects the exposer time as one would expect (brighter for slower FPS, darker for faster). In the last page of his section on Syncro Scan, Barry says, "The short exposure times when overcranking, and long exposure times when undercranking result in different amounts of crispmess or motion blurr. If you don't use the shutter degrees of Syncro Scane (and instead opt for fixed exposure) you won't have to compensate for exposure, but your footage won't be nearly as filmlike." I know 24fps standard shudder is 180d. Do I simply have to set it to this when using variable frame rates to get the appropriate motion blur or do I have to adjust it to the typical one for each different frame rate?
