Barry_Green said:Well, I'm thinking about it like this: SDI is a digital signal transfer device, and so is firewire. SDI is used on big decks and such, and is expensive; firewire is dirt cheap. I wonder if HDMI won't be the "firewire" equivalent to HD-SDI? It sure seems like it would.
That's the comparison I was thinking of. It's Sony's hi-def standard which, in all honesty, is pretty damned good. Capturing straight to a hard-disk is pretty neat. I'm wondering when someone'll tap it and make a Firestore solution that caters to the V1s HDMI out. Tasty.
The Intensity/Blackmagic site is claiming that you get 1920x1080 instead of 1440 HDV size. How is this possible when the camera itself processes 1440 to tape? Here's the link: http://www.blackmagic-design.com/products/intensity/quality/ Here's the EXACT quote from the site:
Intensity uses full resolution HDTV which is a massive 1920 x 1080 pixels for every video frame. HDV only uses 1440 pixels wide due to the limitations of the small cassette tapes used, and the FireWire speeds build into the cameras. However new cameras being released such as the Sony HDR-HC3 with built in HDMI video output, allow access the raw uncompressed video from the CCD directly. That provides incredible quality. Or if you're capturing off HDV tape, you can still enjoy editing video in full resolution, so your graphics and effects look sharp, because only uncompressed video eliminates the horizontal scaling that’s required when rendering HDV footage with graphics and effects.
It's probably a stupid question but it sounds like the HDMI out is similar to Andromeda? (minus the 4:4:4 capabilities and all).
DVi is the only thing I've ever seen come close to HDMi quality and granted, while they're pretty much similar they're both much better than an Analog signal. If you're able to build a tethered solution for "uncompressed" HDMI around a 250.00 Blackmagic card?
Yeah... well... I'm not so certain about dropping my saved up 5k for the A1 anymore (camera cost + accessories).
Though, HDMI cables are expensive as hell. >=\ Just imagine having to find one at a twenty-foot (20') length at a reasonable price that'll still retain high quality?
