Matthew McEwen
Hi,
The history of the FS-100 updates is as follows (each new update incorporates all the previous version fixes)....
version 2.0.0.04080806:
- Various disk performance improvements
- Improvements for 24P support
- Improved compatibility with Final Cut Pro as an AVC device.
- Handle audio recorded at end of clip properly
- Changed the behavior of the organize p2 progress bar. Now it is similar to the OS upgrade progress bar.
version 2.0.0.04061606:
- Auto Stream Detect
- The thumbnails displayed correctly from P2 Viewer and FCP
- When in EXT TC mode, Non Drop is correctly detected
- Added the unlock (UNLK) front panel confirmation screen
- Support 999 clip limit properly
- Enabled a timer to update TC/UB DISP screen every second
- Fixed the thumbnail's aspect ratio for HD clips
version 1.0.0.04061906:
- Fixed Avid Import Clip issue when powering down between recordings.
version 1.0.0.04052606:
- Oxford Semiconductor 1394 Bridge chips configuration updated upon System Reset.
Regarding some of the other issues, the number one issue that most people still seem to see is due to the fact that the 2.0 upgrade was done, but a System Reset after the update was not done. Basically, if no system reset is done, some of the changes do not take affect.
At IBC, we also announced version 3.0, which should be available later this year. This will add native 720p24p, 30p and 25p support to FS-100 which will more than double record time. It is also possible to record in the QuickTime file format allowing direct import to Final Cut Pro. This is relevant for both standard and native modes.
Hope this helps,
Matt
Hope this helps,
Matt
