no sound when recording to DVDR
scorsesefan
I cut a scene in FCP, but couldn't burn to DVD because early version of IDVD doesn't do 16:9 conversion (retarded, no?) I printed the scene to tape and tried to record to DVDR from my Panny(100a), but there's no sound. What am I doing wrong?
Thanks in advance for all who respond.
Crossing out the obvious...
Just to make sure the obvious aren't an issue...
1) After having dumped to tape on your DVX did you do a video and audio check at that point? In otherwords, is everything on the tape okay?
2) What connection(s) are you using to feed to the DVD Recorder?
3) What brand/model is your DVD Recorder?
4) The cables using to feed into the DVD Recorder work fine with another tape or connected to a different device?
Also, btw, not sure this is quite the right thread, as this isn't really an HVX technical question. But anyway....
Cheers
