vegas06
I just received my NEW DV Multi Rig yesterday, and was able to play with it a little bit last night.
All I can say is wow, Danny did a GREAT JOB on it. He definitely hit a homerun with this should be a real WINNER!
It's a sexy dark black aluminum color, extremely well built, and very lightweight (did I say lightweight). It took a little bit of figuring out configurations on my part (20 minutes), but it is actually really easy to configure.
This little rig seem to be stiffer (better for true shoulder mounted shooting) and sturdier than my DVRig Pro. The DVRig Pro seems more fluid, but this is probably because it is one entire rig. The Multi Rig is very fluid once you change the configuration from shoulder to fig rig style.
BTW, shoulder shooting with this can be done in 2 configurations.
1. Using the back attached bar. one would be the typical setup where the back bar is facing downwards (good for placing the accessory plate on the back for a battery and such).
2. The other configuration (I got off of the Dvtec.tv site) where I turned the back bar sideways and let it wrap around my neck. This gave me a very stable and comfortable shooting style, and allowed me the use of the left hand to make camera adjustments without any sway (Fabulous).
I then tried several free hand (fig rig style) shots (with the handles turned upwards), both with and without the support pod.
I can definitely see shooting for a very long time in this mode with the support pod fatigue free. Both shooting styles were stable and very smooth.
I attached my Varizoom remote to the left handle and was able to use it either handles up or down. Although when facing upwards the remote is upside down so I have to remember to operate in reverse when in this setup. I am right handed, but placed the remote on the left grip, because (no matter what configuration I'm in) the left grip is always in use.
The other 2 gips (shoulder, moves to front when in non shoulder mount use), and the right grip (has the QR pate attached to tripod placement) is used up front with the left grip when shoulder use is needed.
It sounds confusing, but very easy and quick to switch from one mode to the other.
You can mount accessories on the handles (either top or bottom) and take any 1/4 tread attachment. So you actually have the ability for 6 mounting points if needed.
I don't have any footage yet, as I was just testing it out last night, but will be sing it on this Saturdays small shoot, and may try to post a clip or two if I get a chance. I will try to shoot using wireless, shotgun mic and on camera light.
BTW, I LOVE the fact that it fits perfectly in my bag while attached to the camera.
I'm sure with some experimentation, I will be able to find the (attachment configuration) perfect setup to shoot all day with (shotgun mic, light, wireless and light battery).
In conclusion, my overall opinion of the DVMulti Rig, is that I can see myself using this for almost all of my shooting styles (I shoot event videos). The form factor is small and very stealthy and light. In just one night, I have figured out about 8 shooting configurations already, and will undoubtably find even more in the future.
All I can say is that if you are in need of a one of a kind do it all support for your camera, this is more than definitely worth a look!
If you haven't already then you can check it out here: http://www.dvmultirig.com/
