getken
Recently acquired a Brevis35 (Rev1) and spent some time yesterday playing with it. It's a cool tool. I did some work outside and then set up this dolly shot inside to see how it would handle a low light situation. I did find that even after my intial outdoor tests (I'll maybe post some of that later) I was still not zooming in enough on the GG and if you look closely at the right hand side of the frame you'll see a little bit of fluttering. It is the GG moving. It gives it a very filmic look but I wasn't trying to do that and I actually ruined a lot of shots from the outdoors test because of it.
I used Nikon lenses and have labeled on the clip which shot is which lens. The 50mm appears to vignette although I couldn't see that effect as I was recording (720pn 24p). The 85mm strobes a little on the dolly move (move was too fast for tight shot). I awaiting an adapter for canon lenses. I have a very nice set of FDs and look forward to seeing how they perform.
For a low light situation I think the camera looks very good and the lenses worked pretty well.
http://homepage.mac.com/getken/hdtest/iMovieTheater47.html
I've also posted a couple of shots of the setup:
