jade8472 said:Used properly, the FX1 and the DVX produces comparable SD results in term of image quality (assuming that you're using the 60i mode on the DVX). However Mack is right, it's better to shoot in HDV mode and then downcovert to SD in post than to shoot in DV. This gives you better option in case you want to go the HD route instead of SD. I believe it'll give you more data in term of color space, but I have not found this to impact the results in anyway.
I would say that the FX1 has the advantage of being native 16:9, while the DVX is 4:3.
deedive said:Yeah, other than that red thing, the footage looked much better downconverting in the nle. If I do any processing, I do it to the hdv. Yeah it takes allot longer but the footage comes out 10 times better. Plus I can do effects to the hdv like slight oversharpen (etc) so when it gets to SD its even better. If there are time constraints then downconvert in camera.
If u have the time edit in HD. Get a final. Export to SD. look at it. Do more work to the final (effects, just for the SD conversion) See how it comes out.
I fought with myself for 6 months over buyin an fx1 or dvx. Buy either one u WIN!
disjecta said:More detail in original HD footage is going to survive a downconvert to 480. I'm not sure how to explain it but it is just a fact. Take a look at any well-shot film that originated on 35mm and you will see that it is clearly more detailed than DV-originated footage.
When I shoot HDV and downconvert it using Vegas (the best downconvert tool in my experience, does a spectacular job), the results are far superior to anything I could ever capture with the DVX.
