After reading some threads about the effects of a clear protective lens filter on the image, I decided to do some tests today. I shot the same frame with and without a (clean, nearly brand new) Tiffen 82mm "Clear" filter on the lens.
The results confirmed my suspicions: There is a significant difference with and without the filter. The difference is most pronounced in the screen grabs below, where I purposefully found some lens flare to exaggerate the effect, but other shots, with the camera in the shade, also showed a less dramatic but still detectable difference. Darker parts of the frame showed the greatest changes. At longer lens settings, the effect all but disappeared.
I'll be stepping up to a Schneider filter now to see if that helps...
