HowdyDoo said:I'm not sure if I have superhero vision, but I've had no problem pulling focus with the HVX LCD. I get crystal clear results everytime.
I just purchased a Redrock M2 so I'm getting a Marshall anyway, but when I'm shooting with the HVX by itself, I'll more than likely always use the stock LCD.
But that's just me. Try it out and see. If you have the money and have a hard time discerning focus on the HVX LCD, then get the Marshall. If your budget is tight, then don't worry about it. You'll be fine.
AshG said:Although I dont care for the camera, I find the Z1u to be the easiest to focus with. FOr whatever reason the on-board LCD works better. Probably a combo of 60i and Sony tech.... still... you should never rely on it with the lens long.
ash =o)
BrianF said:I don't yet have a field monitor to use with my HVX. I have found Focus Assist to be adequate for setting focus initially. (I zoom all the way in, hit Focus Assist, focus the shot, zoom back out. I keep EVF Detail on all the time.) Under controlled circumstances, I haven't ended up with any shots that appeared unexpectedly soft when later viewed full-res on an HD Cinema Display.
However, when things change during the shot (camera position or subject position), that's when it gets me. I often can't detect a subject going slightly out of focus while just using the viewfinder. Last week, even with the camera on the sticks and locked off, I unwittingly recording a suprisingly soft closeup because the actor leaned in slightly. If I had been watching a 17" monitor, I'd probably have seen that happen right away.
Given that (to my eye) the HVX looks better the longer the zoom setting, I'm definitely trying to work on my left thumb dexterity. Run-and-gun with this camera (and probably any HD camera) is a real challenge.
