Noooooooooooooooooooooooooooooooooooo. (Slow motion heartbeat.)planetearth said:the rule of thumb seems to be (or used to be) 24pn for broadcast (interlaced 29.97) and 24pa for film out.
To cinetools and reconform after a 1 hr to 90 minute fine cut is insane and virtually impossible (if you ever want to move on to your next gig before you die).
Forget all this. First of all, you never, ever, want to deinterlace 24p footage. You want to remove the pulldown. You want to do this because if you deinterlace, you not only screw up your motion cadence (because the wrong fields will be removed), you throw away up to half your vertical resolution, too.Colour correct with curves (Color Finesse)
Export a self contained Reference file from Final Cut Pro
Bring into Cleaner = Deinterlace Auto Adaptive, Blur Mild, Sharpen 2.3 + 50 Radius, Adaptive Noise Moderate, Gamma 30, Contrast 19, Saturation 9, Codec Apple Photo JPEG (the thing about converting to DV to Photo JPEG is you don't have that damn colour/luma problem when you go to DVD - Gamma 30 also compensates for Mac computer)
Render out and bring in to Bitvice.
Bitvice = 4.10 – 5.50 – 7.90 – High Precision – DVNC 2
That's what you need to do.PS - I think from now on though, I'll just shoot 24pa. If I have to add any 60i footage I'll just run that through Nattress and convert to 24p.
24pA for editing on a 24p timeline. 24p standard for editing on a 60i timeline.
Is the 24pn for broadcast and the 24pa output to film scenario just a myth
