Pictures of my HVX/M2
Here is some pictures of my HVX/M2 package, and a list of everything I own.
HVX 200P
2 - 8 gig P2 cards
M2 Nikon mount (hard mounted to camera, and custom batt. mod.)
35mm f2
50mm f1.4
85mm f1.8
Redrock FF
Marshall HD monitor (Pany batt. upgrade)
short D4 cable
Indie Snap Matte Box
ME66 mic
VIDLED onboard light
Noga arm
Spiderbrace 2
4 batt. Turbo Charger (TC400)
7 batts. (1 Pany and 6 SCPAN-6000)
....very nice....I need to find me a shorty component cable.... length of the one that came with the Panny is nice.....just too long for my setup.
Sweet lookin' rig brother! I've got same set up except for the Marshall and mattebox. Waiting for RR to come out with theirs. How are you liking the Marshall with the Noga?
cheers,
JP
Nice setup! Whats your address?
Wouldn't you like to know.
That is the one thing I do not have yet. The tripod pictured is a friends.
Cool looking setup, but doesn't all that other stuff get in the way of the VIDLED onboard light?
Yes it does get in the way. I don't use the VIDLED with the M2, I just put eveything together to show what I got.
So how did you do the custom battery for the M2?
It is about $3 worth of parts from Radio Shack. A gutted out "C" Battery holder, 2-9volt battery snap on cables wired together.
Behold my drool. Does that VidLed give you enough light for the M2?
I don't use the two together, but I don't think it would, the HVX+M2 eats a lot of light. I use the VIDLED for more run and gun stuff without the M2.
The weight of the Marshall can be a problem, you kind of have to crank on the knob on the Noga arm pretty good to keep it from moving around. I'm waiting for the RR as well, The Indie Snap is worthless.
cool, lets see some footage.
I'll try to get some footage up shortly.
whats that art holding the monitor up? is that a strain on the rear screw mount? Is that an hd mini monitor? What do you do for your client monitors - turn them upside down too?
thanks
Nice Setup. Can you tell us where you got the short RGB cable. I am also interested in aluminum labels for my equipment. I noticed you have a label. Did you find a good deal on them?
1. It's a Noga arm
2. It seats deep into the screw mount and doesn't seam to be a problem.
3. It is a Marshall V-R70P-HDA With Nebtek Upgrade.
http://www.nebtek.com/proddetail.php?prod=101MarshallVR-70P-HDA-LI
4. If the client monitor doesn't have a flip function, yes I do turn it
upside down.
The cable is 20" long, they also have a really long one if anyone is interested. Here is the links for the cable and BNC adapters needed.
1-Cable- EDIT: read next post before you click link.
https://www.digitalconnection.com/store/Product_List.asp
3-BNC adapters
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=134156&is=REG&addedTroughType=categoryNavigation
As for the lables, they are just custom address labels. I can't remember the site, but I made them online and instead of an address I had it say "This is property of Triple 20 Entertainment". It was like 300 for $8, very cheap.
Sorry for some reason the cable link is not working right, but I'll navigate you. Follow the original cable link above, click "HOME" up top, Type "D4" in search box. It should be the 3rd one down. The longer cable is the 4th one down and has male RCA's intsead of female RCA's like the short one.
Hi Brian,
I have an M2 as well, and really can't seem to nail edge-to-edge focus. Does your "locked" setup work well, and could you descibe it?
Thanks,
Rob
Brian,
Thanks for the link. So did you mimic the setup as outlined by Steve? Do you have the same edge to edge sharpness as illustrated there too?
Thanks,
Rob
dvInsight,
I did the same thing that Steve did, and I am getting edge to edge sharpness. But keep in mind different SLR lenses can change edge to edge sharpness slightly depending on what fstop you are using. If you can help it try not to have the fstop all the way open on the SLR lens and you'll be fine.
Thanks,
I have shot for years (35mm still + standard def Video) and understand the issues of stopping down from wide open to hit the optical sweet spot. The M2 I started with had issues and I had to get a new ground glass (plastic) which improved things greatly, but it has been one adjustmet after another ( I had to drop the motor down too) and edge to edge sharpness has proven elusive.
This is something that I have not spent minutes on, but hours and combinations of lenses. So anything that locks everytthing in place is a giant step forward. I can probably forgo the excellant Zacuto plate for now and just lock it all up. The equipment list looks fairly modest.
Thanks,
Rob
