DorkmanScott
Okay, I got my HVX earlier this week. Right now I find P2 and FireStore drives both to be prohibitively expensive so I'm working on capturing directly to the 2.16 GHz Intel Dual Core MacBook Pro (standard options).
I was having an issue with getting it to capture at all, but deleting the preferences solved that. I can import 720p24 without a hitch, it's when setting a variable framerate that I have the problem.
When I capture directly from the camera via Firewire, I use Capture Now, Non-Controllable Device, DVCPRO HD 720p24 preset. That preset has "Remove Advanced Pulldown/Duplicate Frames" active, but when the video is captured it is still 59.94, with duplicate frames aplenty. When I go to Tools > Remove Advanced Pulldown, it says something to the effect of "Final Cut could not find DVC or DVCPRO NTSC video in this clip" and the duplicate frames remain.
It occurs to me that since it's capturing to 60P, maybe I should be setting the capture setting to 720p60? (I would test it now but I won't be home with access to my camera until later tonight.) Would that remove the duplicate frames? I would think that it would require being told to map to 24 though.
Any ideas? Or information you might need to give me a hand?
