Letus35 + DVX Commercial (if your bored)
That is the cleanest I've seen the Letus look, was the A version or just the letus? Also, what lighting did you use? You got that letus dialled in man. Good work.
Its the letus35aFlip . Most of the lighting was pretty basic stuff. The only
"not cheap" light I used was a basic soft box. I also used one 60 watt "Natural sunlight" light and used it for the key light shining straight at them for the backlight
I used a 75 watt halogen (ya know the ones that kinda act as spot lights)
then I turned on every light and lamp that was in that room
it was originally going to be an outdoor shoot. After I got everything set up. It started raining. So I just used what I had. Its actually raining in the background, but I don't think you can see it.
