scharky
To kind of go back a few posts, I think it is interesting what Haakon said about the HVX looking like it is equal to the 28mm lens, Haakon, you don't know how just very close you are.
Remember everyone, a 28mm lens at 2.8 is a 28mm lens at 2.8 is a 28mm lens at 2.8.
The only thing that is changing is your field of view. Remember also, the HVX does not have a 32-400mm lens, it has 4.5-55mm lens, or something around that. So when you shoot with the DVX at 28mm your depth of field will be the same as if you shoot with a 35mm lens at 28mm, the difference is that on the DVX lens at 28mm this is a semi telephoto field of view, whereas on the 35mm 28mm lens, you have a very wide angle view. Hope this makes sense and can clear up some confusion.
