Which format to save HD footage in Avid Xpress Pro HD?
Kimberli
Hi people!
When I am starting a new project in Avid Xpress Pro HD, which format would I set my HD footage?
If I don't want super high def 1080, which setting would be next best? 720P/24P? If my HVX is set at that, then which do I set my Avid project as?
Thanks,
Kimberli
For best results you will want to match your project settings to the same format & frame rate you shot the clips at.
If you shot at 720P/24PN, then at the NEW PROJECT window (when you open avid), go to format and select 720P/23.976...
Thanks so much you guys!
And thanks for the specification of which frame rate to use "23.976" that really helps!
