Brian Petersen
I just got the HD M2 from Redrock and I’ve been doing some tests, especially inside because I’m trying to see how well I can get in low light. First off I LOVE this product and HIGHLY recommend it. You have to tinker to get the right settings, which is what I'm in the middle of, but in the end I'm going to be one happy clam.
These tests use three different lenses, and then I shot the same shot without the M2 with stock HVX lens. All of this footage has no color correction.
Some notes:
- I was shooting this myself so I would set focus and then run into the shot and then fake talking to people. As a result the focus may be slightly off (especially in the 28mm) but I think I got pretty close.
- The lighting was a simple Home Depot work light. Nothing fancy, and no backlight or fill to speak off. The lack of extra light really shows on the 28mm because there simply wasn’t enough light for the wide scene and the lower f-stop on the wide lens
- I realized color was really hard to tell. I shot the thing then went to FCP and the difference between how it looks on my laptop and on my External monitor was quite large. I have the Marshall 7” coming so I can’t wait to see accurate color.
- There is some added noise due to the compression, but the original is very clean. After shooting this I have NO reservations about noise in low light with the HVX.
- I am still trying to get the edges sharp and I’ve gotten pretty close, but not perfect, which is evident in the charts.
- Yes, that is a Brittney Spears pillowcase laying on the couch I used for focus help, and I’m holding a “That 70s show” DVD to look at depth of field
Here’s the link: (the first seconds are black. Forgot to put a title in there. Opps)
http://www.thinktankthemovie.com/HVX/hvx_and_m2_480.mov
Also here are some links to some frame grabs from charts I shot with the different lens. I don’t really know how to shoot charts so you can’t use it for true resolution. Also, I don’t know how to frame them up the same. For example, with the 28mm I couldn’t get the chart close enough to fill the frame and still be able to focus.
Best to RIGHT CLICK and SAVE these:
HVX:
http://www.thinktankthemovie.com/HVX/hvx_z75.tif
105mm:
http://www.thinktankthemovie.com/HVX/105mm.tif
50mm:
http://www.thinktankthemovie.com/HVX/50mm.tif
28mm:
http://www.thinktankthemovie.com/HVX/28mm.tif
Like I said I still see some edge softness and I'm trying to eliminate as much of it as I can with more testing. My setting are a 75 on the HVX zoom and a 17 on the focus.
Some notes:
HVX:
105mm:
50mm:
28mm:
