newtodvx100a said:From the illustration on Adam Wilts site your frame grab is perfectly normal for the third frame in 24p which is shown as interlaced.
24pa will give you interlace free video. I think that is what you are after.
http://e-motionsmedia.com/K&J mix2.mov
That's not what it's showing -- the C frame isn't "interlaced"; the illustration shows that it's reconstructed from fields of what would be thought of as two different "frames" of 60i video. The thing is, in 60i video, there ARE no frames, only fields. The fields brought together to reconstruct the C frame are the correct two fields needed to make the progressive frame.
I thik it would be better for all if the whole concept of "frames" when referring to interlaced video would just be done away with.
If you're using an NLE which can remove standard 2:3 pulldown properly, you won't be seeing any interlaced frames at all once you're in 24p.
