AJA IO Break Out Box for up to 10 bit SDI
tvacom
I have moved up to the HXV200 and no longer need this box. It was only used for 6 months becuase I moved to LA and closed down my production studio and I have been working for others and used there equipment. I am onlining Jamie Kennedys new MTV show and at the Post house here we are using the same piece of Equipment. Now you can online your own videos!
I paid 2500 for it and now it looks like you can buy them new for between 2000 and 2300 depending on who you trust to buy from.
Sell for only $ 1500. It is in perfect shape and comes with the Firewire cable and install discs that came with it.
Here is what the website posts on this unit and the link.
http://www.aja.com/html/products_Io_Io.html
Io Features
RS-422 Control Port (Sony), 9-pin D, for machine control
10-bit uncompressed SDI with embedded audio I/O
Analog (10-bit A/D and D/A) video inputs/outputs:
S-video I/O
Composite NTSC/PAL video I/O
Component YPbPr/RGB video I/O
Genlock/reference video (looping)
24-bit digital/optical/analog multi-channel audio:
4-channel AES/EBU audio I/O
4-channel balanced/unbalanced analog audio in connectors support XLR or TRS-type connections
4-channel balanced analog audio out connectors (XLR)
8-channel optical audio I/O
8-channel balanced audio monitor out
8-channel embedded audio over SDI
Audio word clock connector (BNC) for audio synchronization
Front panel status indicators: Power On/Off, FireWire (active/inactive), Ref (Genlock), NTSC or PAL
Front panel mode indicators: Input/Output
Front panel video/audio input source indicators:
Video: Present, SDI, Component, Composite and S-video
Audio: Present, SDI, ADAT, AES/EBU and Analog
PRice Drop to 1300 shipped (US 48 states). I have just booked a job that I am shooting on the HVX and I need to update my breakout box to HD.
