Matt Grunau
Adobe Demigod
Hi all. I have a whopping total of 15 hours on my DVXa. Though I have owned it for many months, I only shoot with it, and rarely use it as a deck. When I have used it as a deck, it was only for tapes recorded on it. I have only used MQ and PQ Panisonic tapes. Sometimes when I capture I get strange audio chriping and cliping sounds. But, I can as yet find no constant. All drivers for computer gear are up to date, neither computer has ever held a game or touched the internet.
Ok, here goes:
The chirping does not occur in the same places on the tape. It does not come through the headphones jack, so I don't think it is on the tape. It chirps on both of my 2 computer's different capture cards. Sometimes (like tonight) the chriping was very bad at first, but after a few tries, it goes mostly away. The tapes can sometimes be played back on other cameras (GL1&2GL2s) and are fine, other times there is audio chopping, not the chirping as much as audio skips and what sounds like clipping. It happens with ALC on or off, from the onboard mics & from the mic inputs set to mic or line. It usually happens when the audio is reached more than -12dbs (or so), though it is not clipping. It happens more often in 60i then 24p. Tonight, I somehow managed a whopping 59 dropped frames in under 3 minutes (3 clips in a row, capturing constantly with scene detect enabled during capture), on a seperate, defragged hard drive, and on another computer I got dropped frames on a defragmented C drive. Older footage usually plays with less chirping than newer, but I recently captured over 15 minutes of footage in 24p without a single problem, with multiple takes. It happens when captured with Vegas as well as Premiere.
Here are some mp3s. These are the same tape, same camera (though I did capture the tape with a GL1 and the audio chirped a little, and then went clean), different computers, 10 minutes apart.
http://www.paramm.com/smp.mp3
http://www.paramm.com/smp1.mp3
You will hear the chirping sounds in the music clearly.
I can't for the life of me figure out what this is. A loose or faulty firewire jack? Timecode problems? Cold camera? Dirty heads?
I treat this camera very very well, it has never been bumped, dropped, jostled, been in a dirty environment, gotten wet, hot, cold, or anything else which could cause damage. And again, it doesnt play through the headphones jack, and only 15 hours on the heads.
Someone please take a listen and any help/suggestions/ideas are very welcome.
EDIT: The DVX is the only camera to have these audio problems. I have captured from 4 other cameras and never a problem.
Ok, here goes:
