Vincent Pascoe
heres footage from a feature Im just now finishing shooting called Yesterdays tomorros.
www.myspace.com/vincentpascoe
I cut it my self Love to know what you guys think about it.
Definitely do camera tests and prep all lenses before shooting:
(just like a bigger Production would)
we got the M2 adapter one week into Production..lucky its a multi Story film so using the stock lens for one look and the m2 for the rest worked well.. the first time i got the adapter I had not looked at the online material..(It may take a day to get registered try to do this as soon as possible) it took us 15min to get the adapter up with no instructions....but there was horrible vignetting and the lens wasn't matching up with the Camera...(we put shims in the wrong place) luckily the seen was a girl doing coke so the look worked
as we continued using it we got used to the Lenes and how they worked with the M2, If I wanted more vignetting and soft corners Id go with one lens if I wanted a sharper Image I'd go with another...
I upped the Sharpness on camera a little just to compensate for the m2 wonder if anyone else is doing this?
we did have my AC wile adjusting the Ground glass not secure back on the nut. making the ground glass come off on a take... it rattled inside the adapter and got scratched but still works fine.
and sometimes the ground glass would stop moving....grrr
but all of these problems are probley because we haven't had the time to set it up Properly... We can't even mesure for focus its usually like 10 feet off....
but the director loved the look that he wanted me to do the rest or the film on the M2......problem is my AC had never racked focus in his life let alone WFO on 35mm! so we have had to re-take a lot more because of Fucus. sometimes we have to have our 19" monitor on the Dolly for the AC. making it not great for Run and gun/ Documentary stuff...making the JVC MAgic super 16 adapter make sceene for run and gun stuff...
the director wanted a lot of slow motion and we had a very small Lighting package (2x 1200w hmi biggest guns) there was many times in the middle of a scene he'd want 60fps and I couldn't give it to him because most of my lenses where F/2.8.
ever day I would go back and forth but in the end for feature work I think the M2 is a must have.
the Cartoni Focus was perfect even with the 200mm lens on balanced great. sometimes we would flip the plate for better Balance. the Sticks held up great except for one shot we put a Cobra crane on it and for 2 weeks the Ball head would get stuck when you Loosened it.
I had 2 hard Drives go Bad on me (one segate and one Maxstore) and one wasn't backed up. I had them in Pelican cases but I think the Moving them around beat them up. can not stress enough if the P2 cards them selfeves are raided you should back them up right out of the Cards..
having 3 cards really helped us. we where doing 12minute takes on one day and the AC would slide them 2 me and I would pop them in during a CAmera move to hide the Shake of puting the Cards in.
the camera behaved great we did lots of over cranking and even some 2fps...I'll post more when the shoot is done.
Vincent Pascoe
www.vincentpascoe.com
HVX-200
1x 8GIG card
2x 4 GIG cards
Cartoni Foucus
centry .6 wide angle adapter
varizoom
NIkon mount
28mm F/2.8
50mm Macro f/2.8
50mm F/2
28mm-105mm F/2.8
70mm-200mm F/2.8
70mm-300mm F/5.6
Vincent Pascoe
HVX-200
1x 8GIG card
2x 4 GIG cards
Cartoni Foucus
varizoom
NIkon mount
28mm F/2.8
50mm Macro f/2.8
50mm F/2
28mm-105mm F/2.8
70mm-200mm F/2.8
70mm-300mm F/5.6
