Boomerang said:Why all over the place?
720/60 can mix with 720/24 only if you advance pulldown the 60 footage, but than you might as well shoot 24pn to start. 1080 can be downresed, but why bother. plus unless you have FCP 5.1 you wont have support for 1080.
_________
You will have complete support for 1080/24p in Xpress Pro HD or Media Composer. P2 will input to DNxHD by usual methods in either system automatically (P2 or tape on MC, or just P2 on Xpress). Currently, however, you cannot digital cut DNxHD to tape from Xpress (DVCPROHD, no problem), but you can from MC, so you would use another system for that. But Avid DVD has just added Blu Ray output from any HD source, so that is a nice 1080/24P solution for either system.
However, I think 720P looks better anyway, and 720Pn is slick (except for the fact that it won't record to the new firestore drive).
Barry_Green said:Never slow anything down in post. That's an old, outdated, obsolete technique that we never have to put up with again. Just like "de-interlacing" -- it's over. Forget about it.
You can shoot VFR in 24pN mode, or in "over 60" mode. If you shoot vfr in "over 60" you can extract the active frames in post using the Apple Frame Rate Converter utility, which will remove the duplicate frames and give you a file that's identical in quality and motion performance to what the same clip would have been had you shot it in 24pN mode.
