Sol M.
I for one, am very glad that Vegas does have this "throwback" feature, as I couldn't imagine NOT using the trimmer. Coming from years of FCP and Avid use, I don't think I would have even considered using Vegas if it didn't have a trimmer.
However, I think Vegas' trimmer is highly underused by most of its users, as a large number are learning Vegas as their first NLE. This isn't necessarily a bad thing, except that it doesn't help you learn the necessary workflow on the more "industry standard" NLEs.
The surprising thing is that while Vegas' trimmer is so underused by it's userbase, it's actually one of the best trimmers out there. "Marking up" clips using markers and regions is incredibly powerful because it allows you to make notes on clips (denoting different takes, scenes, etc.) which you can then quickly review without having to play through the clip each time you want to use a part of a clip. You can then also go back and quickly grab the section of the clip that you want to use, without wasting time creating a selection and cutting it down each time you want to use a part of a clip. You mark it up once, and you're done. This way, you also keep a clean timeline.
The bigger a project gets, and the more source material you have, the more useful the trimmer becomes.
