psts said:I'm finding that not only is LASTCLIP.TXT locked, but every file is locked! Any way of just unlocking everything at once?
Bob Fagan said:Delete lock files on the Mac without unlocking them by first making sure they are in a folder, move folder into trash. Hold the option key down when you select "Empty Trash". If you are doing this from a P2 card, you'll have to do the "get info" and click the unlock check box for the .txt file before moving both the Contents folder and the .txt file to the trash. Then hold option key down when you select empty trash.
