snodart
phally said:snodart:
I have me this for my vibrating gg-> 5, 1cc insulin needles, 3 inch white pvc cap, 72mm black cd case circle, a lot of 35mm slide holders.
I started with 4, 1cc syringes, but found that they transfered a little vibration to the camera. I ended up only using two at opposite corners from each other. With my set up, they are enough to hold the GG in place and prevent it from moving along the Z axis.
phally said:so snodart, how long is your needle part from macro to the gg,
The distance from my macro to the GG is around 40-45mm. I left the syringe parts (white sticks) a little longer (7mm) so that I could move the GG and its holder as needed to get infinity focus.
phally said:i figure the longer the needle (white shaft) the more motion left right, but a shorter distance will mean more limited vibrating?
True. Too short might also transfer some of the vibration to the camera. As I have it set up now, I can't even tell if the GG is vibrating unless I check the led light. Too long might allow too much vibration and thus expose the black frame of the D screen.
phally said:so anyways, my plane is to glue the nikon to the slide holder opening, cut holes in for the grommets and stick the syringe's to them connecting them to the pvc cap and cd circle cut out--> why?
the pvc and cd cut out makes for a stiff platform to hold the gg, put that in between two filter 72mm filter holders and all you need now is a motor and metal tube.
whatta you think?
I'm not 100% sure of your plan here without seeing pictures, but from what I am picturing in my head... sounds good. I'm not sure if this would have been a problem for me or not, but I tried to make the piece that holds the GG as small and light as I could. I was worried that too much weight would cause the GG and its holder to sag over time.
Sounds like you are well on your way to a vibrating adapter!
