faceless1 said:just wondering...but is that Cokin P series 72mm filter adapter male on both sides?
marlenedegrood said:Dan edited his post after he got my attention.....what you're seeing is NOT what he really said, now making me look like I need a check on my emotions. Dirty trick Dan.
If your Beattie is too close to Z1 lens, you will get a slight distorsion (depending how much you zoom-in) and soft corners on the image. Try mounting it about 35-50mm away and zoom-in to fill the frame. If it does not fill the frame, get a Century Optics +7 (58mm) and step rings (72-58) and that WILL do.phally said:i guess to much zooming, the light gets dispersed and becomes very soft athe edges.
I think I could add to the above ; The cheaper the macro, the more barrel distorsion. Achromatic lenses provide a distorsion free image.phally said:also, the stronger the macro, the more barrel distortion.
i am at a 10+, before it was at 20+, so took one out it is fixed.
Beattie should have its grooves towards the SLR lens and the matte side towards the camera.phally said:also if yo have major barrel distortion on the edges, then it is that your ground glass need to be flipped.
cheap and good don't go together well, do they? Seems to be one or the other. Anyway, I am happy to know you enjoy a bright image. Sort out the achromat and distance and if need help, call me 604-780-1818. I will help you sort it out.phally said:You will greatly be rewarded with a bright image, unique bokteh, and hella of an area to zoom.
but a intensecreen is a lot to invest in, i did, i bought two, and will buy a third
phally said:hey thanks,
i will get me a new macro, when i have the money, but are there any alternative to century optics? don't tiffen makes Achromatic Diopters as well? or can i just use any Achromatic Diopter?
