Alex DePew
Señor Schmarty Pants
The set-up
I am putting together a DVD for a kids fencing tournament. The tournament was an hour long and has 18 chapters. I edited the footage in Premiere Pro 2.0, encoded the file as a wav and .m2v and imported that and menus I created into Encore. The structure of my DVD is that the main menu gives you the option to 'play all bouts' or 'select individual bouts'. The play all should, well obviously just play the whole file. The select individual bouts takes you to the first of four sub-menus listing the bouts.
The problems
I can't get all play to work the way I want. I searched google and read a few tutorials on this specific issue but for Encore 1.5. I imported the whole timeling from Premiere Pro as 1 large 3.3 GB file. Their solution was to set the end action of one timeline(they has several files and each had their own timeline) to be to play the next timeline. So I created several timelines by dividing up my file by chapter into several timelines (very time consuming and probably not the right way). I then followed the tutorial. I got it to work but the problem is now there is a black screen and a pause before the next timeline starts. What am I doing wrong? I feel like this is a simple problem, but I can't get it solved. I just want the DVD to play straight through without any abrupt pauses when they select play all and have the individual bouts be selectable as well. I tried setting up the play all linked to another timeline that had the one file with no chapters and that worked but it saw it as another 3.3 GB that needed to be on the disc. I am using single layer discs and it won't fit.
Please help me Obi Wan Kenobi. You're my only hope.
The problems
