Running Avid Xpress Pro 5.2.4 on an approved laptop. No problems whatsoever importing MXF files. I've tried it straight from the P2 card, which you can mount from Avid and Avid will recognize as another drive, and by copying the data from the P2 to the appropriate MXF folder as described above. Play's back great as well.
Need to see how the workflow will hold up over many cards and folders though. Copying the files is easy enough, but I too would like to know more about naming the folders from 1 on up. I created the directories manually and named them appropriately for example - is there a way for Avid to do this automatically, and therefore, create the folders, right after the card is mounted in the application?
