Poi Boy
What you are seeing and is quite visible throughout the image is the texture/surface of the element. You may be mistaking some of this as compression artifacts. when the element spins you no longer see all that junk. You get more or less the same effect on the m2 if you forget to turn on the motor that is why I'm so sure about this and why it is unusable in the current design.
-A
Aloha
-A
Aloha
