david jerome
I hooked up my new DVX100b direct to my Sony TV and also a high quality Sony video monitor at work. Both monitors are interlaced. Went straight from camera to monitors with both video output and s-video output, same result. Using the F1 factory setting. I switched between progressive off & (30P, 24P, 24P ADV) everything else the same, still on F1. When in any of the progressive modes I see much worse jaggies on vertical lines with extremely slow panning. More noticeable when zoomed wide. I have heard that the jaggies, artifacts, aliasing, whatever you call it, is there because it’s an interlaced monitor. But I’ve never heard that progressive mode makes these jaggies worse. The traditional diagonal jaggies seem to be the same with progressive on or off. It’s the vertical lines that I’m seeing the difference. Also, changing the different detail settings in the scene menu doesn’t seem to affect the problem. Sorry for the long post but I wanted to make clear what I was talking about. Does anyone know what this is? And more importantly, is progressive mode worse on vertical lines than interlace mode when shooting for interlaced TV. Thanks for any insight on this.
