ProMax SteadyTracker Xtreme for sale (Los Angeles)
  • Thread starter Thread starter DC
  • Start date Start date
DC
Cinematographiliac
______________________
SOLD
_________________________
ProMax SteadyTracker Xtreme for sale in Los Angeles area. This is a camera stabilizer for use with cameras up to 8 lbs.
http://www.promax.com/Products/Detail/6214
Like new condition. Includes manual, a carry bag (not included if you were to buy it retail) and a DVD instructional video.
Pay less plus no shipping or tax: $250
Come check it out and pick it up in Los Angeles area.
Top Ten Reason to Purchase a SteadyTracker
1) Dreamy floating motion shots opens up a new dimension of shooting style. High impact, dramatic, and artistic results always get comments. The 3-axis balance, extended mass, and inertia, takes out unprofessional camera shakes, bumps and wobbles without taking away control. (Balance means nothing without control.). Lets you smoothly move the camera, just like they do in feature films.
2) Easiest to set up With the twist of one knob the camera is on or off the top of the SteadyTracker. Optional universal stage mounts to tripod.
3) Easiest to Balance Uses sliding adjustments, no weights to mess with. Also easiest to rebalance after adding or removing accessories.
4) Easiest to use Less than 5 second learning curve. Its kind of like aiming a gun, it shoots where you point it, and it stays there without wandering off on its own. It takes less than 7 minutes to set-up, balance and use! (Proven on the included video tape)
5) True One Handed Operation You can even change hands for some really long shots. It has the lowest wrist torque- so no cumbersome wrist supports or body vests are necessary. We will never sell a support vest because of their complexity for set up, balance, use, training requirements, limited performance, lower back and leg strain issues.
6) Most versatile
a) Hand held motion machine, level or at angles, even upside down.
b) Body supported on leg, or against your body for static shooting, ready to go into motion.
c) High shoulder mounted shots- even imitates some crane type shots.
d) Monopod positioning on floor, chairs, tables or cabinets. Pans and tilts from a static position.
e) Tripod mode for locked off shots. You can also leave the camera on the SteadyTracker for a convenient place to work the camera while editing or digitizing.
7) Best Design - SteadyTracker Rated 1 by a panel of reviewers at Video Pro Magazine. Aircraft quality all aluminum construction for years of dependable day to day use. Entire unit breaks down to a 24 x 6 x 4 inch package for travel. SteadyTracker Xtreme includes a mount to add accessories, a leveling leg feature in the tripod mode, three year guarantee and may be ordered with a non-dedicated color LCD monitor. Designed and refined by actual "Professional Video Cameramen".
8) 7 minutes or less "set-up, balance, and use guarantee." Balance is so simple that the two step instructions are printed right on the device. Video shows set-up in under three minutes.
9) The most awesome performance. Produces the most dramatic motion shots. Run faster, tilt and Dutch smoother, start and stop quicker. CGX technology yields the least horizon rocking (seasick effect) You can jump off walls, go up and down stairs or over rough terrain, even walk over picnic tables. Works in the wind, or with dangling cables. Optional low cage with tilt feature is available. To sum it up, "Makes my work look more professional and less home made". Kathy Schaeffer - Executive producer of Estates on Video.
10) SteadyTracker gets the shots that get the jobs. Impress your clients, impress your friends, impress yourself. Produce the best camerawork that you are capable.
Monitor and Camcorder not included
It seems that the guy who was originally going to buy this rig is not going to come through. So, if anyone else is interested, just PM me.
Thanks.
D~C
Well, that's a broad question. It depends on what DIY stabilizer you built and how good you built it.
The SteadyTracker works rather well. But it is not as good as a full, professional rig. Of course, those usually cost in the thousands, especially when you get up to Steadicam.
SOLD
Yes, it works with a DVX. I sold it to fund other accessories which I'll be purchasing soon.
