Zoom h4n or h4?
Are you running that 1/4" plug from a different preamp.
Yes, I'm taking the output of a mixing console.
Is the trick to avoiding phantom power on the second input is to use a 2 conductor plug, not a TRS? Or does the 1/4" input jack actually only have 2 conductors. It does say unbalanced and 1/4" in the manual, not TRS, and I don't have a TRS to try it with. Either way, sounds like I should buy an xlr to unbalanced 1/4" cable.
As far as I know, the H4n combo jacks support XLR and 1/4" 2-conductor inputs. Although I've seen Inputs #1 and #2 referred to as "XLR/TRS Combo Jacks" (and even done this myself), there's nothing in the H4n manual, or on the Zoom site that suggests that these jacks support TRS (tip, ring, sleeve) 3-conductor plugs.
If someone knows otherwise, let me know, but all the indications I have (from researching this a bit today) is what I wrote above. - Tim
First of all: Tim, thanks ever so much for all the helpful advice regarding level adjustment! Having listened to your recording in the meantime, I'd consider myself fortunate if I can come up with a similar result. Thank you.
Now that I've read the most recent exchange, I'm thinking about input and plugs again...
The manual specificies unbalanced TRS, nothing else, but using either balanced XLR or unbalanced TRS apparently makes a difference for the input level, if I'm reading this right:
"(balanced input) −10 dBu _ −42 dBu
(unbalanced input) +2 dBu _ −32 dBu"
Since we talked about keeping the level low enough, I'm wondering whether it makes sense to use a TRS adaptor for the connection with the mixing board? Would that work at all, or does this idea just illustrate the degree of my ignorance? ;-)
I'm ever so grateful for this discussion...
Cara
It's not an ignorant question at all.
That's actually what I'm doing, but only because of the connectors that are typically available. Electronically, you should be able to reduce the level down (using either of the methods we discussed before), but you may end up with a bit less noise if you come in through the 1/4" (unbalanced) inputs. Many mixing boards have both XLR and 1/4" outputs, so if your H4n will be close enough to the board, you might be able to ask for 1/4" and be done with it.
The best thing you can hope for is to arrive early enough to set things up, get some levels from the person mixing the audio and running the board, and adjust your levels accordingly. If you can bring an XLR-1/4" adapter or two along. I usually keep several XLR(male)-1/4"(male) and XLR(female)-1/4"(female) in my kit. The female-female adapter also allows me to use a 1/4"(male)-1/4"(male) guitar cable to go from XLR(female)-1/4"(male).
I'm looking forward to hearing (and seeing) the results. It sounds like you're doing all the right preparation. - Tim
I'm very glad to hear that this setup actually works! I'll place the H4n close by the board anyway, and I've already set aside all adapters and cables that may come in handy. (No male/male or female/female XLRs among them though, as the necessity somehow never arose, but thanks for the recommendation! I'll put those on my shopping list.) The movie suppliers where I'm renting all my camera equipment will be able to provide any that I don't actually own, though.
I'm definitely planning to infest the venue as soon as I can get in, and I'm sure I can work things out with the person operating the board, now that I can explain all that's required in the necessary detail.
The actual shoot is next weekend, but I'll be busy with another job throughout the week, so I had to prepare for the sound recording stuff well in advance. You've been a tremendous help, Tim, and I really can't thank you enough. :-)
Oh, and I'll be glad to share and show you the results of my efforts when we're done!
Thank you.
Cara
Stereo mode xlr inputs
:lipsrseal I read the entire thread and especially the technical support by Tim, however I cannot get my new zoom h4n to record my guitar xlr input and voice, sure 58 microphone with ohter xlr input simultaneously. I do not want the 4 channel mode as this mode is perfect for just recording guitar and voice....top quality....
I did try the other modes but I want no room noise and I do not want to plug in via the mixer as my studio is far from my home where I record basic voice and guitar demos.
Now while I can hear one output at a time....meaning first the guitar....then the voice, I cannot record simultaneously voice and guitar by connecting the xlr jacks simulaneously as the instruction booklet suggests.
I also read the suggestions by tim
in 4 channel channel recording namely
Use the scroll wheel to select one of four mixing options:
  1. Built-in Mic Level
  2. Built-in Mic Pan Control
  3. External Mic Level (the XLR-1/4" inputs)
  4. External Mic Pan Control
however my version 1.40 only has the first two listed accessible via the scroll wheel to mixer setting and not external mic level and external mic pan control
I spent two days trying to solve the issue.
Also the 4 channel only records the guitar and external mikes and not the voice input via a sure mike xlr cable.
Could it be that I have to get a splitter or a I need a Y-cable with two 1/4 plugs
Any suggestions would be welcome as I need to get a demo out to a producer with my new songs as soon as possible and this zoom h4n which was hailed to be simple is truly a nightmare. I have seen other songwriters who have successfully used the stereo mode with external mikes with no problems. I cannot even get the minidisk 1/4 mic to work plugged in the back.
Could there be a problem in the device being faulty? Or am I doing things wrong.
Any advice would be welcome. I only needed a simple digital recorder but this for me is only a hassle which is preventing me from continuing with recording and songwriting.
As I said I do not want to use an external mixer or the onboard mikes as they pick up room noise which I do not need. I only bought the device as it advertised the possibility of using two external mikes simultaneously whether these be voice (and my microphone is dynamic a sure 58), and a guitar or guitar and keyboard or whaterver.
Thanks again
