Working with MPEG-2
They Live
What is the best way to work with MPEG-2 files in FCP?
Unfortunately the only version of an old movie of mine that I want to edit into a demo reel is an MPEG-2, with a separate Dolby sound file. What are my options as far as preserving the best possible image and sound quality, and working with these files in FCP? How can I get the Dolby 2.0 into a format that FCP understands? Or am I just screwed? Or is their anyway to edit a timeline in DVD Studio Pro?
Any help would be greatly appreciated.
Ben
You really can't edit MPEG-2 in FCP. If you did, like native HDV, it's a royal PITA.
I'd open it in QuickTime Pro and Export it to the format of your final output. If you're going out to SD DVD, save it out as NTSC-DV. Same for the Dolby file, save it out as an AIFF. FCP will handle the editing of that really well.
I posted this earlier. I'm having some problems installing my MPEG-2 Playback with QT Pro 7.
http://www.dvxuser.com/V6/showthread.php?t=79648
Quicktime Pro alone does not let you work with MPEG-2 files unless you've also bought the MPEG-2 Playback Component from Apple. If you have any suggestions on why that isn't installing, I'd be thankful. It's being a PITA.
As for right now, I'm testing out Compressor. I'm just worried about how much quality I'll lose.
I'm exporting the MPEG-2 out to a 10 Bit Uncompressed file, as well as a standard DV-NTSC file.
What will happen in this work flow?
MPEG-2 > DV-NTSC > MPEG-2
Should I expect a lot of quality loss? Would it be better to go this route?
MPEG-2 > Uncompressed > MPEG-2
Sorry, I'm starting to realize that this should've gone in the Output and Compression Forum.
MPEG-2 is a very compressed format, so you're starting off with a format that doesn't have that much data anyway. The quality loss is already there. DV-NTSC is a HIGHER quality codec than MPEG-2, so you won't really lose much of anything.
MPEG-2 playback is included in QuickTime Pro when you install it with FCP.
Convert with mpeg streamclip. I have had to do that with a lot of material on a current project. Works like a charm. Your images won't get any "better" but gaussian blur + a bit of 3 way CC'ing to add some contrast does wonders on bad and blocky mpeg 2 images i dvcpro 50.
Gunleik
