Windscreen for Sennheiser MKH-416 ?
Re: Windscreen for Sennheiser MKH-416 ?
I've used both. The rycote on a really windy day was not that effective. We had to get some black flags on c-stands to block some more wind. The lightwave i was using indoors came out pretty darn swell.
I can't really compare because i used one indoors and one outdoors.
I believe thats the difference.
Hi Ray, the MS106 from lightwave is a little more effective, since on a really windy day you can slap on the hi-wind cover (just like the softie) and get double the protection for about $85 more. With the softie by itself, you are limited, and can't expand in a hi-wind situation. The softie is used by many pro's though, and is a great tool. :)
If you can go with the lightwave system and add the furry then it'll be better... if you're going to compare each system at the exact same price then I'd say to get the one with the most fur. I've got a lot of softies and several blimps with jammers and I used to think that the softies were almost as good as a blimp/jammer... but the blimps are better by a pretty wide margin. When I used a 416 I used the softie outdoors and the stock foam indoors and things went pretty well like that. Basically the softie will do okay up to about 15-20mph breeze... with the higher wind bringing in some rumble. It's a bummer that these wind systems cost so much, but they do and even on that pricey scale... you still get what you pay for!
A blimp/jammer can handle nearly twice the wind of a softie.
You can sum it up like this... wind requires fur and the higher the wind the longer the fur and/or the larger the dead airspace required around the mic...
