Why do I have to render???
gualbert
First, I read your sticky note Noahk for capturing 24PA. Second, I searched and the only suggestion doesn't work for me. My settings are capture for pulldown removal (yes, it is set at 29.97 so it can recognize which frames to remove), sequence at 23.98. When I capture FCP says the clip is 29.97. When I open the same clip with Quicktime it says it is 24. Help!
Thanks Scott, I checked and had those settings. Problem still.
Well, finally found the issue. Seems like if FCP reach the end of tape (or timecode) when capturing for whatever strange reason it tags as 29.97 a perfectly 23.98 clip. Weird I know, so to work around and get my 23.98 clips I had to stop capturing just a sec before the of footage reach end of timecode.
