White Border on Rotoscopes from Luma Key?
BryantStanton
Couldn't find a topic that had already been made on this subject, so I apologize if there's one I missed.
I'm finishing up a project for a digital effects class, and I'm pretty much all done. The project doesn't even really need to be finished, and it's current state will work fine for the purposes of my grade.
However, here's my issue. I'm doing a shot where I rotoscoped out (first time, taught myself!) a person to clone them. It all worked out and looked great except for one thing. I ended up doing a luma key (my transparencies came in white which was unexpected, but worked out mostly) and my rotoscoped objects I've composited in have an odd white outline to them. the rest of the white background keyed out fine, but this outline won't seem to go away.
Any tips on this for future ventures?
Oh and if anyone is interested in seeing the clip I'll gladly post it when I get saved to a better format.
Thanks!
Sounds like a premultiplication issue with your alpha channel being interrupted wrong. What did you roto/composite in?
If it's not a premult issue then you may need to clamp the edges using a matte choker or something to that effect. Need more info to help...
I exported my sequences as a TIFF sequence, then dropped into Photoshop and roto'd each individual frame. I know there's better ways to do it, but I was interested to see how good the results could be in PS. After I was done, I saved each frame once again as TIFF and imported back to FCP. I then used a luma key to delete the background. The files in PS were transparent, but since it was TIFF it made the background white
Did you save the TIFF's with an alpha channel? I can't see the movie seeing how I'm at work, but there are a few steps you could go wrong with here. Have you tried a matte choker?
