Voice Over vs Location Recording??
borax
Hi,
I have a low budget HD shoot coming up and want to get some input on getting the best audio I can. The dream is to get some sort of distribution deal and having good audio can only help my chances.
Most of the time when I watch low budget films the sound is very flat and greatly impacts the quality of the entire production.
Several posts seem to suggest that over dubbing the voices in post is the best way to achive a professional sound. I have heard that most feature films almost entirely overdub the audio in post. Is that usually true?
If so would it make sense to follow that same idea, using a home recording studio, or should I just try and get the mic as close to the actors as possible and use a mixer to get the most out of the signal?
Can a wireless mic be used to get a full sound or are wired mics always prefered?
I know having the best gear and years of experience is the solution, but when dealing with cheaper gear is it better to try and treat it as a scratch track and re-dub as much as possible in post, even if its in a home studio?
A "professional sound" is not achieved through ADR. Production sound, ADR, effects, foley and music all play a part in most feature films.
You can record ADR in a home studio, in the same way that you can record foley in that same studio. That's a pretty heavily qualified "can," though. Assuming you've already tackled the basics (mic's, recorder, video synch/playback), you still have the issue of accoustics: it is very difficult to make a small insulated V/O booth sound like a medium-sized living. Your mixer will have to have access to a very good reverb engine to pull it off.
Even then, without foley coverage (or some very detailed sound effects editing), your characters will sound like disembodied heads delivering their lines. All those little details that are captured as part of well-recorded production sound will be missing unless foley is mixed in with ADR. Even with the above home-studio ADR caveats in mind, I would venture to say that most home studios are far better suited to ADR than to foley.
There seems to be a trend on this forum lately towards a belief that ADR is somehow more cost-effective and/or easier than production sound. After all, you're going to have to record intelligable production sound anyway (or else try to record ADR without a reference track). Many films have been made without the need for ADR, and many more have only required ADR for isolated lines (getting a better performance, last-minute dialogue changes, "clean" edits, etc.)
But don't just take my word for it. Shoot some dialogue (at various angles) as a test, and go through the home-studio ADR process in microcosm. That way, you'll be better able to judge your own skill level, as well as the time (time=money) the proccess will require.
Oh, I almost forgot:
If the distributer requires that you prepare a M&E (music and effects) version of the mix, you may well need foley coverage anyway.
SMuir said it very well but left one thing out:
It also depends on the skills of your actors. ADR is not something that actors can just do. It requires practice and better than usual acting skills because often all they have to work with is the original footage, no one in the booth but them.
They not only have to match their mouth movements, but have to achieve the same energy, emotion and connection they had on set.
If you are intending to ADR lots, then let you actors know up front. I always take far more careful notes when I'm acting and know I'm going to have ADR than not. And you must record a scratch track that can be synched with the video. I had to ADR a film once with no scratch track on a scene that was improved, with, you guessed it, no script supervisor. I was literally trying to read my own lips in order to remember what I had said.
Phil
SMir, Your description of the various challenges to ADR work were very helpful.
I realize that a lot of work goes into all aspects of the audio production and with this project I intend to work very hard to ensure I make the best film that I can with the equipment and techniques I can afford.
The reason I posted about ADR is because latley I have been hearing and reading more and more about the use of this technique.
The fact that in some classic films the audio was entirely made using this techique, and that since so much work is involved, I find that ADR is mentioned as a way to prove ones knowledge of audio production.
I will probably not end up doing ADR but I wanted to get opinions on wheter or not you can get better audio this way.
Hey quick question sorry not trying to hijack this thread,
What is the best way to mix your audio? A friend suggested getting a cut version of each scene into an adobe audio program and mix it, then would I add the music and score in that program opposed to Final cut or Premier pro?
What is a good audio mixing program?
ADR is a tool to patch up location sound shortcomings not a shortcut to skimp on getting good location sound. Plenty of big budget movies have a lot of ADR because good location sound was not possible. Stormtrooper uniforms making plastic rubbing noises, wind machine in the green screen shot to make the actors appear outside, excessive street noise in the Time Square shot, or the back half of the Titanic set still being constructed while shooting in the front half. There are a million things that force productions to use ADR but it is the last choice (except Spaghetti Westerns).
At professional sound studios ADR is done at the fast pace of 10 lines (that is 10 sentences, not 10 monologs) per hour. At your home studio, with no prior experience in ADR, cranking out a couple lines per hour might be doable. Also, actors often get burned out after a couple hours of ADR.
As SMuir said, do a test run before you start production. After learning what a nightmare it tends to be you will take the extra time to shut that dog up, wait for the plane to fly over, or do another take for sound.
In the end you will probably have to ADR some dialog no matter how hard you try but you will be a much happier camper if you minimize it as much as reasonably possible.
Good luck
Adobe Audtion could work but lacks a ton of features to do it effeciently. ProTools is the industry standard (with good reason) but Nuendo is also quite excellent at about 1/4 the price of a Digi002 Protools with TC setup.
Cheers
No, it's not. I have also read people saying such things too, and I wonder where they get that idea. Some say it's budget related, so multi-million productions dub everything. To comment on that and really identify if anything was really dubbed you need experience.
No doubt you can dub anything, but to do it properly you need a lot of experience from the actors. Not only for syncing, but for syncing and acting as they did during shooting. Very hard to get, and IMHO never gets to the emotion you get during actual shooting.
Acting is moving and talking, and when you separate that you are in trouble.
Using a sound person during shooting is the best thing you can do. He will analyze every situation and pick the best mic for it.
Usually a mix of them.
Even a cheap mic will work fine when it's in the right position. Never mic from the camera. Always get as close as possible to the subject, from above, to at least two feet from the mouth. Use an angled position and use directional mics.
This is the basic way all classic films in history were made, and it still works. Start from that.
Do not think that you will dub anything. Dub only what's imposible to hear. Let the ambience "noise" bring reality to your film. But don't let it overwhelm it.
Work on your ability to mix those two things.
Carlos
Let's also be clear - your title on this thread is very misleading.
There is a big difference between "voice-over" and ADR. Voice-over is kind of like narration - it is spoken over some footage or image and does not represent an actor actually speaking on screen. ADR is Automated/Automatic Dialogue Replacement - and believe me, there is nothing automatic or automated about it. ADR is when you have to replace the words spoken by an actor on-screen for one reason or another. These reasons can be anything from bad background noise obscuring the dialogue to a decision to actually change the dialogue (often done when the actor is not facing the camera - if you can't see the actor's mouth, basically anything can come out of it). It is also possible to replace dialogue in a take without needing to go into the studio and do an ADR session - by cutting in such a way that you don't see the actor's mouth and pull the necessary lines from another take where the recording is clean/cleaner.
Phil
Which brings up the benefits of rolling sound on rehearsals and recording wild lines while the performances are still fresh in the actors' memory. As long as everything is organized and notated for easy access in post, your dialogue editor(s) will thank you.
Ptalsky, your right about my error in the title for the thread. Too bad it can't be changed to ADR. When I was posting I really didn't understand the complexity of the process.
These are some great responses, and I have learned a lot from them.
I will take your advice on getting the best audio I can in the field.
Thanks again
BTW does anyone know how much ADR work Quentin Tarantino does on his films? Someone told me he prefers it and uses it heavily.
I've been using SawStudio for years and love it. Video track allows ADR/Foley work too and it will even let you do some limited editing of the video if some adjustments are necessary. 72 stereo or 144 mono tracks 24 stereo outputs.
Vegas Video 7 also works very well and has extremely good sound capabilities.
Stable multitrack performance is necessary for all the layers of sound effects, music, dialog, etc. you need to do it all the right way. I've found both Vegas and Sawstudio to be extremely stable and reliable.
Can't comment on Q, but I just watched the director's commentary on El Mariachi (Rodriguez) and he shot that whole movie MOS (without sound) and ADR'd everything.
His point was he was able to move much quicker with a smaller crew and get many, many more shot setups.
I think the others here are right though - you should try to get good field audio. You should also grab wild tracks, foley, room tone etc. so you're set up for post and ADR too.
You're going to need be knowledgable in both. As you gain experience it'll be pretty easy to decide which is going to be the better route for each scene. For instance, I've been on sets where planes are going overhead every two minutes... if you're ALWAYS waiting for sound you'll add days to your shoot while ruining everyone's morale. Just move on and ADR that stuff (IMHO).
Boy I would sure love to understand how not having a sound person on set sped up the shoot process and get more shot setups. At the very least you can capture a scratch track and have something to match to in ADR. Also, it would be interesting to compare how much longer post was because of the lack of audio.
First of all, if you pick a location with airplanes flying overhead every 2 minutes, shame on you for selecting such a stupid location. And, it is a very bad precedent to say that sound is expendible on every shot. And, I do not understand how anyone would have lower morale. Everyone on a project should be focused on delivering the best product in every department. As a soundie, do I get demoralized when we have to wait for an hour for picture (light resets, etc.)? Of course not. And, when you talk about morale on the set, how do you think the poor sound guy would feel if he is told that the work s/he is doing isn't important enough to worry about. I would never accept those kinds of conditions working on a project.
When I start a project, the first think I tell the director/AD is this: If sound calls for another take, please treat it the same as if picture said the last shot was out of focus.
Then it is my responsibility not to abuse this right.
Phil
OK a couple of points.
ADR is not cost effective unless location sound is not possible.
Most films are not entirely ADRed, not even close.
Films like StarWars where production sound was wrong sounding (the big stages sounded very different than a space ship) and had a lot of noise from the mechanics of making the live FX happen, tend to have very large amounts of ADR. But not most films. Big budget films go to great lengths to avoid using ADR (even if the have recorded it). Titanic had 90% + of the dialog ADRed because of all the construction that was going on (they were building the set and the studio (FOX Baja) while shooting. BUT only used a bit under 50% because of the great work done by the dialog editors to create usable tracks from the takes.
ADR is hARD to do well. And it is EXPENSIVE to do well.
A sort of exception is a lot of Hong Kong action movies and some european directors, who ADRed everything often shooting no production sound at all. But they are not doing real ADR because they are dubbing to another language and nobody expected tight lip sync.
Always get the best production sound you can.
ADR won't give you the "Hollywood" sound. Hiring a good sound team can. That polished sound is because, as opposed to most indi films, Hollywood spends a good deal of time and effort in making a good track. The typical Indi spends all the budget on production, sets lights, camera and on visual post. The picture editor often is paid. Then you see the ads looking for someone to do sound for free as a "good opportunity", and of course thee is usually no time allowed either. Someone who may have spent a few years and $100,000 on shooting and editing often has allowed close to nothing and a few weeks to edit and mix the sound. A decent sound track takes somewhere between 10 to 20 man-hours per screen minute to edit. Then a day + per 10 min. reel to mix. This is true with few exceptions from the smallest non budget film to the huge Hollywood epic. Assuming you have people who know what they are doing. That is what gets you that polished sound. You can raise the $$$ and pay everybody or you can often get it done with in your budget by paying in other ways. But you can't ignore it till the end and try and get a rush job. I always recommend you get your sound post person about the same time you get your DP. They might even do the location work for you so that they will have better stuff for post. But at least they will A) know that you care enough about the sound to have them involved early and B) know what they are up against (sound wise) before it all gets dumped in their lap.
