I have heard good things about the Matrox DV codec (chroma interpolation), so I have done a comparison with the Vegas internal codec (decoding only). These tests were on a 4.2.0 PAL footage. The 300% zoom on pictures is made in photoshop to see more details:
fix camcorder, progressive recording:
As you can see, the Matrox codec does a really good job, but there is a problem in interlaced.
next test, light in a club, interlaced:
Seems the Matrox codec see 4 fields (???????), where the Vegas codec see only 2 normals fields. The image from the Vegas codec can be de-interlaced properly, but not the one from the Matrox codec. Tested, in Vegas, Virtualdub, Win2K, WinXP, but the Matrox gives this bizzare 4 fields in interlaced. I have also tested moving images in progressive mode and in some pictures, I've seen lines artefacts (less evident). I would like to use this Matrox Codec as my new decoding codec (as you I suppose) but I can't find a solution. If you have one, let me know.
Here is the settings in the Matrox codec:
