Using Drop frame and non-drop frame together
Huaw
Hi,
Hello I'm an editing newbie and I'm trying to find out if it is okay to use both drop frame and non-drop frame in the same sequence? I am an assitant editor working on a project shot in SD and HDV. The problem is 95% of the footage is in drop frame. When trying to capture via a Kona card using the 720p 59.94 preset the clips are changed from drop frame to non-drop frame as indicated by the colon between the seconds and frames. When capturing through Firewire, FCP's helpful scene detection "feature" will keep the drop frame timecode but sometimes slices up scenes that have no scene breaks making new clips where none exist.
We are working on a new Mac Pro using FCP 5.1.2 and a KONA LHe card. We are also using a JVC 720p HDV deck. The editor may need to work in two different places so we'll need to use the Media Manager. This is for broadcast.
If it doesn't matter if we use both drop frame and non-drop frame in the same project then we can move forward. Otherwise, any suggestions would really be appreciated. Sorry if this question is really stupid but I'd like to know.
Thanks in advance,
Lynne
Throw one of each in a Timeline and see. My guess is that they'll play together fine. In fact, I drop DVCPRO-HD and NTSC-DV on the same timeline with no problem. One is drop frame, one is non-drop frame. They play very nice together.
And FCP has no "scene detection" feature during capture. That is a huge mistake lots of FCP users make. When capturing, with the preferences setting you refer to, you're telling FCP what to do when it finds a TC break that should NOT technically be there, not when you start and stop recording. That's a different function. That's the DV Start/Stop detect feature you use after you capture.
Technically, when you start and stop recording, the camera should not create TC breaks on the tape, although many cameras do, but their not supposed to. The DV Start/Stop detect function reads time of day code, not the SMPTE TC used in capturing.
I don't use a Kona card, have no idea what it's doing.
Anyway, you can drop both frame types in the same Timeline.
Again, if you set FCP to create a new clip when it encounters a TC break on capture, and you use that to seperate scenes based on when the camera started and stoped reccording, you're really mis-using the function to do something it's not meant to do.
I have an article on the DV Start/Stop Detection feature and it's workflow in my Cut Lines column. Go to EventDV.net and search for "Cut Lines". All the articles are on-line there.
Thanks for responding,
These forums can be really frustrating sometimes. Sorry, I used the wrong phrase. I was trying not to write a big long question but... We've been trying lots of work-arounds. I've learned a lot about what you can and can't do. I tried using a batch capture list when capturing the HDV material but it would get a streaming error or timecode break error every time it would come to what it saw as a break in the time code. When I saw this I thought great, I'll change the "on time code break" setting to make a new clip and capture that way. The problem with that was that it would detect a time code break where there was none and break up a clip into several clips with a couple seconds missing at the beginning of each clip. This happened during a clip of an interview where the camera was not turned off or paused. I read an Apple document that said they did this (scene detect, time code detect, whatever you want to call it) on purpose to help speed up logging and capturing. I also read an article: http://finalcutpro.digitalmedianet.com/articles/viewarticle.jsp?id=33061
This probably is a great idea, when it works but for documentaries, where you can't always plan your shots and for the reason I just mentioned, it's a real pain. So since the Kona changes the clips to non-drop when I need drop and the HDV 720p30 slices the clips indisciminately, I was trying to see if it's okay using non-drop and drop in the same sequence.
Thanks for trying to help,
Lynne
Um, I'm not understanding. You sound like your mixing the two different functions. And capturing HDV is the same as capturing any other. That article makes a very misleading statement. He needs to re-word what he's saying.
If you set your preferences to just capture and warn you after a timecode break, that's how you set it in order to be able to use the DV Start/Stop detect, which I use all the time in my rather large documentary project. I'm still not clear what your problem was with that, it works flawlessly for my consulting clients, too.
But towards your main question, yes, you can mix drop and non-drop, shouldn't be a problem.
My question, why capture via the Kona if it's changing the timecode format? Is there a need to capture your HDV that way? Just wondering.
Good link. I published that same tutorial a few months before that. It's a really great function, especially for wedding/event videographers and for us documentary makers.
Well I guess we're not going to agree on this. I can only point you to the Apple article: http://docs.info.apple.com/article.html?artnum=301715 . And draw your attention to where it says
"Warn After Capture
When you capture HDV, this option behaves identically to the Abort Capture option."
That's exactly how it acts in FCP 5.1.2. Maybe it acts differently in other version.
Thanks for your input.
Huaw
Hurry Up and Wait
OH yeah, that's due to having to conform to the Long GOP that HDV uses. Yes, that's a slightly different issue. Of course you loose a second or two here or there, it's the native HDV Long GOP structure. Cuts in any NLE can only be made on "I" frames. That's perfectly understandable, that's all they're saying.
I'd never capture HDV as native, I'd use the AIC, I don't know why anyone would want to edit native HDV when you need frame acuracy, cause you can't get it with the native Long GOP of HDV's MPEG-2 structure.
Now I understand what you mean. It's only different with HDV due to the MPEG-2 Long GOP structure of native HDV. Use AIC and youwon't have that problem. Nor will you lose any image quality at all.
