Disregarding noise from working the camera controls, the problem is not the proximity of the mic to the camera per se, the problem is that the camera is usually going to be too far away from the subject for a mic at the same distance to deliver good sound levels. It doesn't matter if it's on the camera or 5 feet to one side, if the mic to subject distance is the same as the camera to subject distance, the sound is not ikely to be very good. Your camera is probably going to be 8 to 15 FEET from your speaking subjects to provide a pleasing framing for your shot. But optimally the mic needs to be within about 30 INCHES of the speaker to give a good performance. At the closest distance you're likely to be placing the camera, a mic at the same distance is still going to be 5 feet farther away than it ought to be.
So what are you suggesting?
That extension cables and boompole are unavoidable ?
or I'd rather go the safest route: wireless mic? They rent a set of wireless mic. That should be fine; since only one actor is speaking at a time.
The only concern is that it would probably not fit into a 1/8 jack; so some kind of adaptor would be requried.
