True Meaning of a "Lossless" Codec
Mommaerts
I was wondering if the terminology "Lossless Codec" is the same as say teh word "Stainless Steel" where in fact the Steel will stain but less that regular steel. Does this confirm that the term "Lossless Codec" simply means that the codec will in fact still lose a bit of quality but not as much as say a "Lossy Codec"?
Something i've been meaning to ask for a while now.
thanks to all those who read/reply.
(M)
Re: True Meaning of a "Lossless" Codec
Mommaerts,
Unless there's a deep secret that the general public isn't told, the term "lossless codec" can be taken literally in that no information is discarded when the media is digitized. Therefore you shouldn't lose quality.
My guess is that "stainless steel" emerged from a marketing scheme to fool us all into thinking it's a perfect material...hehe
-Todd
A lossless codec would mean exactly that: the compression scheme used results in no loss of data. An example would be if each frame was compressed using a variant of the LZW compression algorithm (which is what makes .ZIP files so small)... LZW is a completely lossless algorithm, you can exactly reconstruct the data so that it is bit-for-bit identical to the original image.
Lossless algorithms are nowhere near as space-efficient as "lossy" algorithms, such as MPEG, JPG, MJPEG, and DV. Under normal circumstances, the very best a lossless codec will do would be about a 50% space savings -- and that's variable. It could be much smaller, or it could actually be LARGER than the original source data. MPEG-2, on the other hand, is capable of doing a reasonable job of turning a DV-sized frame (720 x 480, or 345,600 bytes) into 1/10 its size and have it still look pretty good. But it's lossy.
I think the Video Toaster VT[3] offers a lossless compression scheme, offering to edit completely uncompressed D1-resolution video, and the way they do this is to implement a lossless 2:1 compression scheme to lower the data rate requirements on hard drives, etc.
Thank you both for clarifying that as well as the extra infor regarding compression. This will help shelve some questionable knowledge I had.
thanks again,
(M)
