Any takers for casting some light on the FCP equivalents of these Premiere functions:
"LEVELS" - Works wonders in enhancing color correction and yields superb results.
"MASKING" - When shooting 4:3, enables you to scoot frame up and down by 50% (25% top and 25% bottom) to attain a cinematic aspect ratio. Gives a ton of room to work with in post relative to frame composition.
"CROP TOOL" - To attain same effect as "MASKING" ... is this the same thing?
Would you achieve the 2:35:1 aspect ratio using "MASKING" and the "CROP TOOL" or would you deploy another method?
Hope the above questions make sense. Frankly, these are based on emulating the Great Disjecta's fabulous work, it would be so much better if we could just get him to switch over to FCP!
Thanks!
Thanks!
