To the FCP experts and gurus... Filter question!!!
gualbert
I have noticed that the order of the filters mildly (significantly in other cases) influence in the final product. Does anybody here knows what works best for the best quality (i.e. less noise, pixelation, etc), I am interested in the order of the filters. References or tips more than welcome! Thanks in advance!
Cheers!
Re: To the FCP experts and gurus... Filter questio
All depends on what you want to do. If you add noise and then blur that's going to be much different than blurring and then adding noise.
If you want to remove noise then that should be done early (first?) before you start making drastic changes to contrast or other appearances. Keep the number of filters to a minimum. Stack them in a logical order and avoid opposite filters. (i.e. color correct bright followed by ones that darken it etc)
In some cases you want to get a good looking image using subtle corrections and then apply your stronger ones. You may want the final color correction to be last so you can easily match clips.
I typically do my dynamics tweaks first (levels, contrast, etc), then color tinting/correction last. Watch your video scopes for hints on what each filter is doing to your image and experiment. The best tool for gauging how good an image looks is your own eye. (watching it on a calibrated ntsc monitor of course) 8)
