surround 5.1 and krk studio monitors
jeghead1
hi all
I have krk studio monitors and the krk sub running from the m audio firewire solo. I want to get another set of krk monitors and get into 5.1 audio for my productions. WHAT sound card should I get to hook my monitors to. The firewire solo only has two outputs so I don't think I can use that. and also do i need a center speaker. please help I am very new to 5.1 but It makes such a difference in films.
thanks in advance:)
edit: i like the m audio firewire 410 would that work if not then the delta 1010
wow nobody out there does surrond huh?
i found out what to use anyway and i hear the motu 828mkII is great. you can get away with the firewire 410 i believe but the converters are worse according to guitar center.
i use the motu hd 192 also have used the 828 and the 2408 they sound great.
if you are just getting started with mixing in surround make sure you take the time to set your room up and get the system setup correct and calibrated.
anything with 6 channels out you would be able to configure for surround editing. A dubber I know says that the two rear channels are nearly always mixed together so thats only 5 channels altogether..
a M-Audio Firewire 410 would do it pretty well for cheap. around £350
look up RME mulitface.. things like that.
